It is currently Tue Sep 16, 2025 2:12 pm
 Post subject: Truss rod placement
PostPosted: Mon Oct 03, 2022 2:59 pm
First name: Ken
Last Name: Nagy
City: Goodrich
I designed the neck around the SM hot rod low profile truss rod. 14 1/2 inch one. The next size up was 18, and that was clearly too long. But I changed the neck to 16 frets to the body join, and lost an inch or so. I think that I'll place it about where it is in the picture. I will close off what is extra at the heel.
Is there a better placement?
Why be normal?
 Post subject: Re: Truss rod placement
PostPosted: Mon Oct 03, 2022 3:51 pm
First name: Josh
I’d probably put it a little further down the neck, so the active end of the rod, just before the nut, was part way between fret one and two. I don’t like having the end of the rod bearing on the neck too close to the nut slot. Depending on how you intend to mount the nut ie in a channel, directly on the neck or peghead surface, this area could be weak and not a great place for a stress riser.
Users browsing this forum: roby and 66 guests
cron
